I have a problem with audio dropped. After one hour, I have these statistics :
Audio buffer (ms) 80/80 ms -> 40/80ms Dropped audio samples 4/0 -> 164/0 Audio resampled (ms) 20/60 ms -> 40/1900 ms
The session works with 3 SDI inputs, an NDI stream, and a dante stream. Sometimes I have an advert "GPU overloaded", wich doesn't appear in the logs. I have tested the audio with a DAW software, and after one hour of recording, it was clean.
I have tested a session with NDI only, with the BM card unplugged. The results are quite good (only 3 audio dropped) Can someone explains me how does the reference between audio and cameras work ? I read that Vmix synchonizes its sources with a virtual Genlock : should I synchronize the audio hardware with the cameras (wordclock and genlock) ?
I work with : -Ram is 32 Go -Intel xeon w-2155 cpu @ 3.30ghz -Vmix driver 22.0.057 -Nvidia p4000 driver 426.26 -Blackmagic quad 2 (driver 10.11), installed in a PCI-express slot.
Thank you, Regards, Christine
