Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hi all, i want to know something is it possible to use the ATEM mini like a control panel with the Vmix? Thanks
I think it is not the case unfortunately, since the ATEM Mini is not a keyboard nor a MIDI controller, and therefore vMix will not recognise it as a controller.
Thanks i think so but just to be confirm!!! unfortunatly David
Joined: 4/23/2017(UTC) Posts: 1,496  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
May I suggest the Elgato Stream Deck. It's a perfect fit for vMix
@ davidci This should answer your questions about how the ATEM Mini works with vMix: Ice
