3rd Party Software and Development
Animation Lag when importing XAML from Blend
Joined: 1/22/2020(UTC) Posts: 47  Location: Montpellier Thanks: 14 times Was thanked: 2 time(s) in 2 post(s)
Hi, I'm currently trying to do some animations on Blend for VS 2017, and it works fine on Blend (On which I'm on NET 3.5) but once in VMIX it's like there a drop frame. I'm trying to ease out the animation to have something smooth. Here are some tests for you to see : https://www.youtube.com/watch?v=...mWQ&feature=youtu.beHere is the code : Code:<UserControl
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:my="clr-namespace:vMixTitleLibrary;assembly=MTA" xmlns:ec="http://schemas.microsoft.com/expression/2010/controls" x:Class="UserControl2"
mc:Ignorable="d"
d:DesignHeight="1080" d:DesignWidth="1920" Width="1920" Height="1080">
<UserControl.Resources>
<Storyboard x:Key="AnimSynthés" >
<DoubleAnimationUsingKeyFrames Storyboard.TargetProperty="(UIElement.RenderTransform).(TransformGroup.Children)[3].(TranslateTransform.X)" Storyboard.TargetName="TextBottom">
<SplineDoubleKeyFrame KeyTime="0" Value="1844"/>
<SplineDoubleKeyFrame KeyTime="0:0:0.72" Value="0" KeySpline="0,0,0.12,1"/>
</DoubleAnimationUsingKeyFrames>
</Storyboard>
</UserControl.Resources>
<UserControl.Triggers>
<EventTrigger RoutedEvent="FrameworkElement.Loaded">
<BeginStoryboard Storyboard="{StaticResource AnimSynthés}"/>
</EventTrigger>
</UserControl.Triggers>
<Grid Margin="0,0,-8,0">
<Rectangle x:Name="rectangle" Fill="White" HorizontalAlignment="Left" Height="114.12" Margin="95.98,756.005,0,0" VerticalAlignment="Top" Width="{Binding Width, ElementName=TextBottom}" RenderTransformOrigin="0.5,0.5">
<Rectangle.RenderTransform>
<TransformGroup>
<ScaleTransform/>
<SkewTransform/>
<RotateTransform/>
<TranslateTransform/>
</TransformGroup>
</Rectangle.RenderTransform>
</Rectangle>
<TextBlock Name="TextTop" HorizontalAlignment="Left" Height="111.048" Margin="95.98,756.005,0,0" TextWrapping="Wrap" Text="Text on Top" VerticalAlignment="Top" FontFamily="Ubuntu Medium" TextAlignment="Left" Foreground="#FF5B83A2" FontSize="57" Padding="0" RenderTransformOrigin="0.5,0.5">
<TextBlock.RenderTransform>
<TransformGroup>
<ScaleTransform/>
<SkewTransform/>
<RotateTransform/>
</TransformGroup>
</TextBlock.RenderTransform>
</TextBlock>
<TextBlock Name="TextBottom" HorizontalAlignment="Left" Margin="100.98,820.952,0,0" TextWrapping="Wrap" VerticalAlignment="Top" FontFamily="Ubuntu Normal" TextAlignment="Left" Foreground="#FF5B83A2" FontSize="40" Padding="0" Text="Text on Bottom" RenderTransformOrigin="0.5,0.5" Opacity="1">
<TransformGroup>
<ScaleTransform/>
<SkewTransform/>
<RotateTransform/>
</TransformGroup>
</TextBlock>
<TextBlock Name="RectSize" HorizontalAlignment="Left" Height="108.995" Margin="132.897,909.155,0,0" TextWrapping="Wrap" Opacity="0" VerticalAlignment="Top" Width="1728.145" FontFamily="Ubuntu Normal" TextAlignment="Left" Foreground="#FF5B83A2" FontSize="40" Padding="0" Text="500"/>
</Grid>
</UserControl>
I might be missing something here ? Thanks !
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
First : your video is set to private
second: what are you trying to achieve here ? Width="{Binding Width, ElementName=TextBottom}"
Originally Posted by: doggy  First : your video is set to private That should be ok ! Originally Posted by: doggy  second: what are you trying to achieve here ? Width="{Binding Width, ElementName=TextBottom}"
My text's width is set to Auto, so it increase/decrease depending on the Text. Then the width of the rectangle gets the Text's width. It's actually doing what we can do from the Bounding option of last version of the GT designer.
