Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
Is there a shortcut or function to change one of the layers in the multiview to another input?
For instance, I want to change layer 3 to input 47 on one of my shots (input 34).
I see the "SetMultiViewOverlay" function. But that doesn't seem to work for me. I am clearly messing something up. http://localhost:8088/api/?Function=SetMultiviewOverlay=3,47
But that doesn't tell what the actual input of the input I want to change. So I have input 47 that has 6 layers, and I want layer 3 to change to input 34.
Get it? Hard to explain.
I can do it by setting a shortcut. But I can't figure out the webapi function I guess is my question.
Joined: 8/5/2017(UTC) Posts: 579  Location: Manitoba Thanks: 120 times Was thanked: 322 time(s) in 184 post(s)
Try the following: http://127.0.0.1:8088/api/?Function=SetMultiviewOverlay&Input=47&Value=3,34 That should set the multiview layer 3 of input 47 to input 34 cheers, Richard
Originally Posted by: raugert  Try the following: http://127.0.0.1:8088/api/?Function=SetMultiviewOverlay&Input=47&Value=3,34 That should set the multiview layer 3 of input 47 to input 34 cheers, Richard That worked perfect for me. Thank you.
