Feature Requests
Error on Http Request Script
Hi.
trying to run an HTTP Request to another software from a script.
the Command is working but there is and error and the script breaks.
trying different methods yet the same Error :
" The server committed a protocol violation. Section=ResponseStatusLine"
Method 1:
Dim webClient As New System.Net.WebClient Dim result As String = webClient.DownloadString("http://localhost/PTZJoy=Camera3")
Method 2:
Dim webStream As Stream Dim webResponse = "" Dim req As HttpWebRequest Dim res As HttpWebResponse req = CType(WebRequest.Create("http://localhost/PTZJoy=Camera1"), HttpWebRequest) res = CType(req.GetResponse(), HttpWebResponse)
Same error for both Scripts...
Any idea?
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 316 times Was thanked: 1021 time(s) in 838 post(s)
Nope :( Same Error.... any Ideas?
can i try updating the .NET on this workstation?
this is from Microsoft:
ServerProtocolViolation - The response from the server is not a valid HTTP response. This problem occurs when the .NET Framework detects that the server response does not comply with HTTP 1.1 RFC. This problem may occur when the response contains incorrect headers or incorrect header delimiters.RFC 2616 defines HTTP 1.1 and the valid format for the response from the server. For more information, see RFC 2616 - Hypertext Transfer Protocol -- HTTP/1.1 at Internet Engineering Task Force (IETF) website.
I guess the problem is not vMix or your script but the answer from the other software that is causing a problem
is there a way to ignore the response?
Originally Posted by: hanan.sharivkin  is there a way to ignore the response? I dunno but Googling in your place i often encounter <httpWebRequest useUnsafeHeaderParsing="true" /> btw , does it work strait from a browser ?
Feature Requests
