Low Delay / Latency Streaming
We are streaming quite a few audition/castings but the delay is a problem for casting agents and talent coaches. Are there any recommendations for locations and options that minimize this delay? I am trying to avoid high monthly/annual fees while providing a solid interactive service. Quality is not important, vs. near realtime speed. Any ideas?
@ bluesman64 If I have understood you correctly, this has more to do with your CDN than vMix, this google article helps to explain some of YouTube's latency options: https://support.google.c...ube/answer/7444635?hl=enOtherwise, if you are instead referring to the inherent delay of digital video processing through a PC, (LIVE to what you see on screen) then unfortunately, there is not much you can do about that and largely why software switchers like vMix are not recommended for IMAG presentations (there is typically a 200ms to 500ms latency on most systems depending on equipment being used). Ice
This is exactly why "live streaming" is not the same as "video conferencing." Bidirectional communication, video conf or telephony, demands low latency. Any kind of CDN is inappropriate.
You can use tools like vMix in conjunction with things like Zoom.US, Blue Jeans, Cisco, Poly, Jitsi Video Bridge, 8x8, Hangouts, etc.
Joined: 8/24/2017(UTC) Posts: 21 Location: Madrid, Spain
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
