StryderTV
#1 Posted : Sunday, February 2, 2020 1:53:26 AM(UTC)
StryderTV
I can’t work out a way to monitor audio whilst shuttling in Replay. This is necessary as if one is using replay and one of the cameras is tasked to do an interview with the framing excluding the interviewer then you need to hear the audio from that camera to be able to adjust the in point to the start of the first question. I know that with the present v23 you have to select which camera audio is used (hopefully improved in v24?) but whilst shuttling you don’t hear it.
#2 Posted : Sunday, February 2, 2020 3:30:49 AM(UTC)
@ StryderTV
I responded to your earlier query in the IR Thread here:
https://forums.vmix.com/...g-audio-whilst-shuttling
Essentially, you need to use the "Solo" [S] button of the Instant Replay Input.
