NDI
NDI Output not saving as MOV in MultiEncoder
Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
I have "Output 1" with "NDI On" in output settings, and when I record "Output 1" with MultiEncoder, although it has NDI enabled and I have the "Save NDI as MOV", it still encodes the video in mp4 (or whatever format I have selected).
How can I ISO record the NDI output 1 with vMix multiencoder (no external tools)?
Thank you.
Joined: 10/13/2012(UTC) Posts: 1,161 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
You choose the NDI input to record NOT output1,2,3,4 etc. Have just tested and all works as designed.
"Record NDI in original MOV format
When recording NDI sources, you can select to record in the same compression format as NDI itself (MOV) by checking this tickbox. This allows recording NDI sources without any additional system load or CPU usage as the video does not need to be re-compressed.
When recording NDI in this mode, all MultiCorder settings except the recording folder are ignored, including audio source and "new file every"."
NDI
