Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
I might be looking at this all wrong as there is a video delay that I am aware of but I am unable to make it work the way I want.
I am wanting to take the master output via NDI of Vmix to second computer as an input to then be able to add 10 second delay to this source to then output it to a stream continously. I then want a second input or video clip on standbay to be able to switch to before the 10 seconds is up if I wish to cut the main output.
So am I missing something or is this possible am I am just not doing it right?
thanks for any ideas
Mark
Originally Posted by: mark  I am wanting to take the master output via NDI of Vmix to second computer as an input to then be able to add 10 second delay to this source to then output it to a stream continously.
Capture input, go to settings, advanced. Choose how many frames to delay maybe ? Stolen from https://forums.vmix.com/...t-by-X-seconds#post11313
thanks for that I can possibly do this on the second computer as cannot do it on first computer as I am already using the imstant reply facility already. if I can make the delayed source on computer 2 able to be cut if needed it might work thanks for the direction ill get back with if it worked properly or not
