Feature Requests
Being able to select audio bus A or B for IRP
Thanks: 186 times Was thanked: 20 time(s) in 17 post(s)
With the upcoming vMix 24 focussing on IRP improvements, please support the suggestions in this thread. +1 replies are very welcome. Thank you all !
Request: allow the IRP to not only use Master or the audio from 1 certain camera, but also to use the audio from Bus A or Bus B.
Even better: allow IRP audio to follow a certain camera angle, in my case: if the event happens on the left-hand basket, record the mic there; on the right-hand basket, record the mic there.
Suggestions from other users (thank you!):
- it would be great to have a shortcut to change the audio source for the replay - it would be great to easily switch between the recorded ambience sound for instant replays, and the recorded commentator's voice for highlight reels - being able to pick any audio recording separate from the video would be good. For example if they offered a 6 in option you could record your program with master audio on one input and then your ISO cameras with NAT sound on the others. Would also be important to auto-mute the output when something is not played at 100%. - this is a must so I can bring in only the ref mic and field mics onto the IR recordings.. Please, please add this to 23, just take out a camera and give me a bus option.. PLUS 100!
 1 user thanked Ario for this useful post.
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
+1
Thanks for collecting the suggestions!
Feature Requests
