irishmike
#1 Posted : Tuesday, January 21, 2020 9:36:31 AM(UTC)
irishmike
Ireland
I have downloaded Vmix, as i like the look and feel of this software :)
I have a mic plugged into the blackmagic atem mini
In Vmix getting audio delay (I have did tests and Adjust the audio delay setting in milliseconds from 0, 10, 20, 30, 40, 50, 60, 70,80, 90, 100, 100, 110, 250, 400, 600 etc)
When you look at the screen you can see the dealy, but its 1000% perfect in Open Broadcaster Software Studio.
Whats going on, I like Vmix, but cant use it..... :(
mjgraves
#2 Posted : Tuesday, January 21, 2020 10:51:19 AM(UTC)
mjgraves
Seems to me the trouble in in the ATEM Mini. It's delaying the audio in appropriately. If you using a vMix, why mot connect the mic directly to the PC? Better control in vMix in any case.
irishmike
#3 Posted : Wednesday, January 22, 2020 12:50:47 AM(UTC)
irishmike
Ireland
what is the best way to plug mic into PC? but the mic works well in Open Broadcaster Software Studio,but in Vmix, its very slow... the audio... dont know why....
mavik
#4 Posted : Monday, January 27, 2020 7:43:28 PM(UTC)
mavik
Was thanked: 191 time(s) in 171 post(s)
you can use the audio jacks or connect via USB. If the mic is analog you can add a little mixer that does the analog to USB conversion.
mjgraves
#5 Posted : Tuesday, January 28, 2020 2:46:59 AM(UTC)
mjgraves
Depends upon the type of microphone. A small mixer is a good option.
Or an interface like this from Berhinger (https://amzn.to/2tY2MyT) accommodates XLR or 1/4" mic connections.
Or this very simple one from Blue Microphones (https://amzn.to/36xxYSS) which is XLR-only.
irishmike on 1/28/2020(UTC)
#6 Posted : Tuesday, January 28, 2020 2:49:36 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
There are no known issues with ATEM Mini audio/video input support in vMix,
(just tested last week and can confirm a/v sync is correct)
so if there is a delay, please email us for support as it is likely just a configuraton issue.
irishmike on 1/28/2020(UTC), eduardocfs on 9/3/2020(UTC)
