rnhturner
#1 Posted : Saturday, January 18, 2020 1:11:53 PM(UTC)
rnhturner
I have 3 1080 60 fps NDI cameras all going at the same time. The cameras will all freeze in vmix (not the camera itself) at the same time and my my stream button goes from red to yellow. After about a minute it works itself out. It seems as the longer I go the more often it happens. At one point I had another laptop going at the same time with 2 of NDI cameras on it. Those feeds did not freeze, so that would seem to rule out connection to my birddog studios. My pc is running about 35%. Ideas??
#2 Posted : Saturday, January 18, 2020 6:16:03 PM(UTC)
Sounds like the network connection on that computer is dropping out periodically.
You can check this by opening Task Manager in windows, going to the Performance tab and keeping an eye on the
Ethernet bandwidth while everything is working fine, if it suddenly drops when the problem occurs it may be a cabling
or network port issue.
