Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
For the last two weeks when I've turned on my PC and ran vMix only, I've noticed it's taking 86% of the CPU. Running Photoshop, Premiere Pro or even After effects don't give me this issue!
Is anyone else having this problem, it's slows the broadcasting down, and twice I've cancelled and stopped live shows (restared PC and still the same)?
I never had this issue before only since I updated to 23.0.0.31.
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
Updating to the latest version (23.0.0.37) might solve your problem.
You may be correct...I see very low CPU % use on 23.0.0.37 on an old laptop .....even less than when I used ver.22....it even seems quicker in launching as well....maybe it does, or just my imagination....never really checked the loading time, but it seems quicker.....so, update, see what happens...
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
Open Task Manager in Windows and view the Processes ab to see what is using the CPU.
Thanks all, I've updated the software and will let you know the outcome. I'm going live tomorrow for about 2 hours so fingers crossed.
Updated to the latest version now. Tested for about 4 hours live streaming and all seemed ok.
