Hey Guys,
i have a question. Is anybody here having a tool or a script to config the elgato stream deck like a hardware controller. If i have two lines with cameras, one line, showing the active camera and one line the preview cams , my buttons putting it into the preview, my question is, is it possible all press buttons have to became another colour if i go to another camera. The same with the active camera. if it became on air, the pressed button on stream deck should be became green. and all don‘ t used buttons have to change automaticly to another coulor, like blue or white., and it should be show me wich camera of the active is in preview, as example in red?
has anybody tested it like this feature? I test to write me a tool but it doesn’t work.
maybe you can help me.
sven
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Joined: 11/3/2018(UTC) Posts: 8  Location: Tarrytown, NY Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
No, not possible. Activators do not do anything to Stream Deck, Multi function switch in Stream Deck does not allow vMix shortcut as one of the functions, this is where I thought I could make this happen.
Originally Posted by: Bob Westerfield  No, not possible. Activators do not do anything to Stream Deck, Multi function switch in Stream Deck does not allow vMix shortcut as one of the functions, this is where I thought I could make this happen. Do I misunderstand ? no activators from vMix to Stream Deck ? SO the Link I gave before is wrong ? Multi function ( Multi Action) does not allow shorcuts to vMix but a single one could ? What about hotkeys , System Website (api calls) ?? not to mention bitfocus companion What am i missing ?
