GT
Data Change CSV Freezing BUG ?
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
CSV is not Updating if i send a data change You can see i send a Point on the CSV file and on this moment it shows the point on the Scoreboard and the animation but the CSV file is freezing, you can see it on the time. is this a bug on GT designer and VMix ?
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
CSV is not freezing , Datasource update check is pausing while the animation is playing triggered by a OnDataChangeIN
Want to see the score change before any other item animation starts use OnDataChangeOUT. Wont change the pause in Data Source refresh though (for the clock pulled from same source)
GT
