Chosing audio device in streaming setup box
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Is there anyway, like there is with recording, that you can chose an audio device.
I want to know this because I want to send the vmix audio trough line out to a mixer >the mixer back in the computer with line in (so you can mix between video audio and mics)> and then for streaming I want to chose the standard vmix video device, but not the standard vmix audio device instead I want to use the line in.
I hope someone can help me and if this isn't possible it should be a next feature. Because you get more control over the audio
Iason
Joined: 3/7/2012(UTC) Posts: 2,663  Location: Canada Thanks: 33 times Was thanked: 510 time(s) in 479 post(s)
I'll defer to Martin on the vMix side, as I don't use it in vMix... You can choose your audio source if you stream with FLME separately, my concern would be echo feedback though.
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
To reduce the risk of feedback I'd suggest monitoring with headphones, and making sure to uncheck "listen to this device" in your "recording devices" settings.
This should prevent windows from sending the mixed feed back out to the mixer whilst still allowing vMix to work with the audio.
Good luck!
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
Do you mean you want the vMix audio output as a virtual audio device so you can select it in Windows as a playback device? I am looking for the same (vMix as a audio source in WME because WME sees only a vMix video source).
In that case you can use a USB hardware mixer. You don't connect the mixers output to line in, but you select the usb mixer as the audio capture source in your streaming program. There will be no feedback because the mixers output will not return to vMix. Ofcourse you can also connect the mixers output to a USB audio grabber.
