hfabeby
#1 Posted : Monday, December 30, 2019 7:14:18 PM(UTC)
hfabeby
China
Link rectangles, images and other GT elements to Text fields set to auto width and/or height.
This allows elements to match the size of the text with an optional padding value on each side.
Does this mean that I can modify the size of image or rectangle in GT in real time through XML or excel,Rectangle or picture size can change in real time according to the value
#2 Posted : Monday, December 30, 2019 7:43:58 PM(UTC)
Sort of yes , the bigger the textbox becomes the bigger the linked items becomes. even changing the fontsize will do that but there is no way to change the font size based on xml data or shortcut
But no one is stopping you from say entering data that has more lines (or have the text be "invisible" to use as a way to control the size of an image through Data Sources etc text ;-)
