Fullscreen on screen 1 under vMix interface
Joined: 9/13/2013(UTC) Posts: 9   Location: home Thanks: 1 times
Hi!
I want to use my laptop screen for full screen preview, but when I activate it, vMix itself seems to be on top, preview barely showing at the bottom of the screen, on the toolbar.
Happens on both computers, a 6 year old laptop, and also the new laptop. Both have Win10.
The version is 21.0.0.61.
You can minimize the vMix window but then how will you operate it ?
Believe it would be better to attach a cheap monitor to your laptop and send the full screen there
Originally Posted by: doggy  You can minimize the vMix window but then how will you operate it ?
Believe it would be better to attach a cheap monitor to your laptop and send the full screen there I use a controller, and need the laptop's 15" screen for preview. I can't fit another big monitor in my planned setup, so that's why I asked for such a precise solution. I still wonder if there was a way to force the preview on top.
Then completely minimize your vMix window after setting fullscreen (-) if you want that window back then hit Alt-Tab to select it (is basic Windows stuff)
Originally Posted by: doggy  Then completely minimize your vMix window after setting fullscreen (-) if you want that window back then hit Alt-Tab to select it (is basic Windows stuff) Yes, I know how that works. I was just wondering why this happens, and if there was a workaround (or a bug fix) that keeps vMix operational. Would be a lot more handy to toggle fullscreen on and off from the controller, since I also need the interface every now and then. Now if I operate vMix while minimized and need to do something my controller doesn't, it's a real hassle since a midi-controller doesn't control minimizing/maximizing.
Shortcuts:
Fullscreen Toggles Fullscreen On or Off
FullscreenOff
FullscreenOn
Dare I say RTFM?
