PTZ speed sliders lowest level not minimum speed
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
When set to the lowest level they do not represent the minimum speed. I have to set them to app 15% to get the minimum zoom en pan speed. Below this setting the speed will increase again.
Is it possible to fix this or is it a camera issue?
(I am using a Sony camera with CGI over IP)
Unfortunately there are not shortcuts for these sliders. Is there a workarround to adjust them remotely (api)?
