lestra
#1 Posted : Monday, December 23, 2019 9:10:57 PM(UTC)
lestra
Saint Kitts And Nevis
Hi. How to get logo overlay all the time without using one of 4 overlay channels? Thanks.
#2 Posted : Monday, December 23, 2019 9:44:44 PM(UTC)
Multiview
lestra
#3 Posted : Monday, December 23, 2019 10:14:13 PM(UTC)
lestra
Thanks Doggy. I mean insert logo somewhere in general and forget. Is there any insert for logo?
#4 Posted : Monday, December 23, 2019 11:08:35 PM(UTC)
NO
but maybe one could do it with altering the ffmpeg code.
do a short test stream , check the stream log file and copy the ffmpeg command line part (Thank DWAM for the recording hint ) , and insert logo code into it (google) open CMD and copy the altered command part line there. external in vmix has to be on ! (you wont have to think about the logo for the duration of the stream if you think its worth the hasstle ;-) )
lestra
#5 Posted : Tuesday, December 24, 2019 1:10:48 AM(UTC)
lestra
OMG that is so difficult for me. vMix please give us logo inserter. Thanks Doggy.
#6 Posted : Tuesday, December 24, 2019 1:17:50 AM(UTC)
input a NDI of the output , multiview with a logo on it and record/stream that NDI input ;-) ( if you have the right license & v23)
mjgraves
#7 Posted : Tuesday, December 24, 2019 2:32:51 AM(UTC)
mjgraves
Take NDI output, use Martin Kay's Zen NDI software to overlay a logo, bring that back into vMix as send it onward to streaming service.
Or use OBS to take vMix program out via NDI, overlay the bug and send to streaming service.
I'd probably do that on a separate computer, to keep the functions wholly separate.
lestra
#8 Posted : Tuesday, December 24, 2019 5:26:10 AM(UTC)
lestra
Ok thanks, I will try suggested solutions.
GeorgeR
#9 Posted : Tuesday, December 24, 2019 8:05:05 AM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
Create a new "Preset" with your logo attached. Then each time you wish to make a new video or live cast open your "logo preset" and build onto your show from there.
lestra
#10 Posted : Wednesday, December 25, 2019 5:16:59 PM(UTC)
lestra
Thank you GeorgeR. I know how to save preset but how to attach logo without using one of 4 overlay channels? It will be better to have insert slot for logo somewhere in Settings/General, I think.
Workaround with multiview works but...
MartLeib
#11 Posted : Thursday, December 26, 2019 9:56:14 PM(UTC)
MartLeib
Estonia
Stream using OBS. Add vMix External output as input in the OBS and add overlay there.
