GT
Ticker with logo's
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
 6 users thanked doggy for this useful post.
Joined: 7/15/2018(UTC) Posts: 110  Location: Las Vegas, NV Thanks: 14 times Was thanked: 9 time(s) in 7 post(s)
Love it! Would be great if vMix would allow for an image delimiter so it'd automatically put a logo between each story.
Originally Posted by: shawntempesta  Love it! Would be great if vMix would allow for an image delimiter so it'd automatically put a logo between each story. Whats the difference with the vid if you keep the same image ?
Correct me if I'm wrong, but the template created is for a very short string of text. If you were to have it for news stories, they flex in length. Just to be able to say "vMix, add this image between stories on ticker" within the program would be awesome. That's all.
if you are using data sources one can always add a special character to the format field (for now) ☻ {0} or something simple externally ;-) https://hologfx.io/
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: doggy  Hi Doggy i'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such thing i found [mytext] [mylogo] [mytext] i also read your previous post there https://forums.vmix.com/...20826-Ticker-with-logo-sit was useful and hope you can help me doing this one and if possible let me see your private video here tnx alot
Originally Posted by: doggy  if you are using data sources one can always add a special character to the format field (for now) ☻ {0} or something simple externally ;-) https://hologfx.io/ Hi, First Tnx for Your Answer then i saw this yesterday it was amazing ! but just a little problem i have is to be RTL not LTR and edvin has no option built on there for direction . any help for this ?
GT
Ticker with logo's
