MaverickLan
#1 Posted : Friday, December 20, 2019 11:12:57 PM(UTC)
MaverickLan
Is anyone aware if there's any way to get an output of the Program audio meter? Either a video feed of the meter OR numerical data via scripting is acceptable...I just haven't found a way to get either yet. The reason we need this is because our audio mixer is about 10 feet away from our broadcast machine and the sound person needs to be able to monitor the audio levels that vMix is putting out.
Our original plan was to give the audio mixer a full-size monitor with a Multiview......but after doing some measurements, we really don't have space for such a monitor, so we'll have to use something like a little Raspberry Pi monitor or similar. Being able to JUST have the audio meter instead of the full Multiview would allow the meter to actually show up big enough to read easily on the small screen. https://scrabblewordfinder.vip https://www.applock.ooo https://www.7zip.vip
Peter1000
#2 Posted : Saturday, December 21, 2019 7:22:41 AM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
use Panel Builder, run it on a 100$ 10" Windows Touchpad
it connects via wifi to your vmix system and you can paint your setting as you want, also faders etc.
Panel Builder here in the Forum
panel builder.PNG (126kb) downloaded 4 time(s).
mjgraves
#3 Posted : Saturday, December 21, 2019 9:50:50 AM(UTC)
mjgraves
NDI makes it easy to access a stream on a remote PC. NDI Studio Monitor has built-in metering.
Alternatively, you can use Darkwood Designs audio meters to measure the stream.
https://www.mgraves.org/2015/05/wide-range-audio-meters/
In that case, you might need a virtual audio cable to route the audio stream.
elvis55
#4 Posted : Saturday, December 21, 2019 8:35:41 PM(UTC)
elvis55
Switzerland
Harmanpubg18
#5 Posted : Thursday, September 10, 2020 7:23:14 PM(UTC)
Harmanpubg18
Its really helpful information framaroot
