Hardware Compatibility
Please help! I keep dropping frames
I have a pretty powerful PC and I really don't think my computer is the problem. I have a 3 camera setup (old Panasonic cameras) I set them to 1080i, 30fps and set up vMix with the same settings. I have 3 cameras that won't work if they are all on at the same time. I use a component to SDI converter and plug it into my Black magic Decklink. It's unwatchable and my Livestream is suffering! Can anyone troubleshoot this or tell me where I can start troubleshooting? Thank you solitaire.onl/ 9apps.ooo/
A first step would be to tell us something about the hardware: What CPU, GPU, RAM, harddisks are in the machine?
Next would be to tell us something about the project you are running: are you running multicorders, replays, movie files?
Also what software is running in the background: any chrome tabs open at the same time as streaming?
Streaming settings can also help: if you encode on the 'veryslow' preset, you need a beefy machine for example.
Finaly a screenshot of statistics (found in the bottom right corner) could help sort out where the frames are dropped: on input, dropped by the gpu, or perhaps frametimes of the incoming signal are not regular.
