Feature Requests
Start from settings config and autoload a preset
We always build our productions using a combination of a setting (.config) and a preset (.vmix). Which means that when we open upp the production we start vMix, import the settings file and then open the preset. There is already the possibility to open vMix by specifying which preset to use. For example, by double-clicking the .vmix file which launhces vMix and opens up that preset. This implies that the most recently used settings file is applied. I would like to see a similar option where vMix, if called with an optional .config file, would apply the settings in that file. And ideally also a new Settings option that specifices a preset file to open, Last, or None (default). This would ease up the production start for us, and presumably many others who also always combine unique settings for all presets. While that improvement is a small deal, a bigger one is for everyone who want to automate the start. A few related feature requests that I have found over the years: https://forums.vmix.com/...ts/t2215-Startup-optionshttps://forums.vmix.com/...t-configuration-checkboxhttps://forums.vmix.com/...ve-vMix-s-window-settinghttps://forums.vmix.com/...more-settings-to-Presets
 1 user thanked richardgatarski for this useful post.
Joined: 3/12/2015(UTC) Views messages in topic : 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
Joined: 10/9/2018(UTC) Posts: 28   Location: Leesburg AL Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
+1
I like this idea, now that I know I can save shortcuts with the preset, why not all configurations as well?
+1
A list of recently used projects could be displayed.
Joined: 6/14/2018(UTC) Posts: 7 Location: Kansas City
Thanks: 3 times Was thanked: 4 time(s) in 3 post(s)
+1 and scripts per preset
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Joined: 8/30/2019(UTC) Posts: 11  Location: Farum Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
+1
You never know you need this.. until it's too late. :)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
+1 thought that's how it worked and noticed too late
Thanks: 185 times Was thanked: 20 time(s) in 17 post(s)
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
+1
If possible as an easily editable XML file as is the case with the Blackmagic Design ATEM switchers.
Joined: 2/14/2020(UTC) Posts: 29  Location: Brisbane Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Feature Requests
