Joined: 1/13/2010(UTC) Posts: 5,318  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
23.0.0.30
* Fixed issue with SRT streams stopping on some systems where more than one SRT output stream is enabled.
 3 users thanked admin for this useful post.
23.0.0.31
* Fixed incorrect version of SRT library included with installer
23.0.0.32
* Added workaround for Google Chrome update causing vMix Video device to no longer work. * Fixed FMLE no longer working as the streaming application. * Updated vMix Desktop Capture to 23.0.0.2 with fix for old CPUs without AVX support.
23.0.0.34
* Updated NDI to latest 4.2 release * Fixed MultiCorder MOV checkbox for NDI not saving when disabled * Fixed BusXSolo shortcut not working * Added 1080p streaming presets for Facebook * Creating a new preset in vMix now correctly resets the 4 outputs * Fixed flicker in preview/output position labels.
 7 users thanked admin for this useful post.
23.0.0.35
* Fixed different flicker introduced by bug fix of preview/output label flicker!
23.0.0.37
* Fixed a memory leak in the SRT input * Fixed GT scroll transition direction not saving when set to Left * A text field in GT with the events disabled checkbox (such as for a clock) will now update even if a datachange transition is in progress. * Input speed may not load correctly from a preset on systems in some regions * Improved playback smoothness for 50p video files.
 10 users thanked admin for this useful post.
23.0.0.38
* Fixed issue when adding an NDI input that has Multicast enabled. * Added support for selecting Mix when using Triggers and Scripting. * Removed SmartScreen warning when installing on a system for the first time.
 8 users thanked admin for this useful post.
23.0.0.39
* Fixed Mix dropdown in Triggers not showing all available mixes. * Fixed a bug in SRT output causing encoder to stop in some situations.
23.0.0.41
* Updates WebRTC library for DTLS 1.2 support, required by Chrome and FireFox in March 2020 updates * Improves connection reliability through difficult firewalls by only requiring a single port to be open for both audio and video where available. (called "WebRTC Bundling") * General connectivity improvements when faced with unreliable internet. * Improvements to video/audio for iOS (iPhone/iPad) callers.
 9 users thanked admin for this useful post.
23.0.0.46
* Fixed issue with latest StreamDeck software update * Increased number of vMix Calls in 4K edition from 2 to 4. * Fixed high CPU usage with multiple callers in 23.0.0.41 update.
 11 users thanked admin for this useful post.
MarkP on 3/18/2020(UTC), ask on 3/18/2020(UTC), BETech on 3/18/2020(UTC), DetoxX on 3/18/2020(UTC), stigaard on 3/18/2020(UTC), raugert on 3/19/2020(UTC), sinc747 on 3/19/2020(UTC), TBacker on 3/19/2020(UTC), avsoundguy on 3/20/2020(UTC), StepBackInTime_TV on 3/29/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.48* New Window capture methods in Local Desktop Capture dropdown at bottom of window. WindowsGraphicCapture is available in latest Windows 10 versions (1903 or higher) and supports capturing most windows such as Zoom and Browsers that previously would have shown a blank screen. * Added Disconnect option to right click menu of vMix Call inputs. * Added Direct Connection checkbox when adding vMix Call. See below for explanation of this option: https://www.vmix.com/kno...l-direct-connection-mode* Moved Low Latency checkbox to Advanced Settings as this should not be enabled in most cases on vMix Call and was causing disruptions for users on congested connections. * Debugging options added to vMix Call to assist us in diagnosing connection issues. * Added workaround for corrupt video and calls on new AMD Radeon graphics cards such as the 5xxx XT series. * Fixed issue where Twitch login window would appear blank on some systems. * vMix Call MultiCorder recordings will now only split if gap is 5 seconds instead of previously 1 second, to reduce the number of files generated when calls are congested.
23.0.0.49
* Fixed incorrect call stats when sending support report.
 6 users thanked admin for this useful post.
23.0.0.50
* Fixed issue with HEVC encoding from Larix Broadcaster when Use Hardware Decoder is ticked in vMix * Faster congestion detection on vMix Call for browser guests to adapt more quickly
* Added new right click Advanced Settings menu for vMix Call with the following:
1. Toggle to turn on or off "Allow only direct peer to peer connections" on an existing calls. (Will apply only after guest reconnects)
2. Remote Guest Video Bandwidth to manually select the maximum bandwidth used to send video from the guest. (This applies to browser guests only, as vMix guest specify their own return video bandwidth) By default this is set to "Auto" but if you think the congestion detection vMix Call uses is not fast enough, or too aggressive you can manually try different bandwidth settings here live, to see which works best.
 17 users thanked admin for this useful post.
pba on 4/2/2020(UTC), userr777 on 4/2/2020(UTC), grantcoll on 4/2/2020(UTC), stigaard on 4/2/2020(UTC), David_in_Philly on 4/2/2020(UTC), StepBackInTime_TV on 4/2/2020(UTC), dmwkr on 4/2/2020(UTC), RingsideReport on 4/3/2020(UTC), xaver on 4/3/2020(UTC), ask on 4/3/2020(UTC), sinc747 on 4/3/2020(UTC), vvcvvc on 4/4/2020(UTC), AgentPete on 4/5/2020(UTC), GeorgeR on 4/5/2020(UTC), stevespaw on 4/6/2020(UTC), avsoundguy on 4/9/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.51
* Improved audio quality in vMix Call during internet congestion / dropped packets. * Faster bandwidth detection for vMix Call when guest bandwidth set to "Auto". * Added -20dB Pad checkbox to audio settings for NDI inputs. This is useful for NDI hardware encoders that send a +20dB signal by default. * Added a 20dB Boost checkbox to output settings for NDI outputs. This is useful for NDI players that expect a +20dB signal. * Fix for SRT input when used with Larix Screencaster. * Set Facebook Live scheduled time box to 24 hour mode in regions without AM/PM. * Recording settings now default to MP4 for new installations.
 16 users thanked admin for this useful post.
stigaard on 4/8/2020(UTC), Tango on 4/8/2020(UTC), doggy on 4/8/2020(UTC), ask on 4/8/2020(UTC), stevespaw on 4/8/2020(UTC), vvcvvc on 4/8/2020(UTC), IrvinCee on 4/9/2020(UTC), sinc747 on 4/9/2020(UTC), avsoundguy on 4/9/2020(UTC), raugert on 4/9/2020(UTC), billh2020 on 4/9/2020(UTC), STADIORADIO on 4/9/2020(UTC), KnightHeart on 4/10/2020(UTC), Scott Barnett on 4/10/2020(UTC), monamiga on 5/8/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.54* Important Change: YouTube is slowly phasing out Stream Now from their platform so we have made the difficult decision to remove it from vMix in favour of copying/pasting the Stream Key. If Stream Now still works for your account, you can follow the steps below to continue to use it until it is finally disabled on 1 September. https://www.vmix.com/kno...he-old-classic-interface* Fix for Twitch chat in vMix Social due to breaking change in API. * Fix for Virtual PTZ not working on AMD graphics * Fix for Activators not updating correctly for C-G audio buses. * Facebook has removed the continuous streaming feature, this update also disables those options. * SRT PCR interval increased to once every key frame. * Optimus compatibility mode moved to Advanced Settings as this was being accidentally enabled by users and reducing performance on systems. * Security improvements to vMix, vMix Update and vMix Desktop Capture to follow current best practices.
 14 users thanked admin for this useful post.
elvis55 on 5/7/2020(UTC), ask on 5/7/2020(UTC), sinc747 on 5/8/2020(UTC), nandomachadouy on 5/8/2020(UTC), raugert on 5/8/2020(UTC), monamiga on 5/8/2020(UTC), stigaard on 5/11/2020(UTC), Slaver on 5/11/2020(UTC), KnightHeart on 5/13/2020(UTC), KnKproductions on 5/13/2020(UTC), raymer on 5/16/2020(UTC), chiscort on 5/20/2020(UTC), Amnon on 5/26/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.55
* Fixed focus issue when starting vMix * Fixed console window that may appear when running vMix by opening a preset directly. * Fixed MultiCorder sometimes incorrectly recording more sources when opening a preset twice. * Fixed Key/Fill not reloading when a Key or Fill input resets (such as due to change in video format) * List input now automaticallt loads correct for certain MP3 files that do not play correctly normally. * Fixed issue with VST plugins that require a very large amount of space for saved settings. * Fixed Virtual Input issue where MultiView layers audio was not turning when Automatically Mix Audio is enabled.
stigaard on 5/27/2020(UTC), dunk on 5/27/2020(UTC), raugert on 5/28/2020(UTC), avsoundguy on 5/28/2020(UTC), xaver on 5/28/2020(UTC), MarkP on 5/28/2020(UTC), sinc747 on 5/28/2020(UTC), KnightHeart on 5/28/2020(UTC), greggibson on 5/29/2020(UTC), Reinaldo on 5/29/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.56
* Updated Web Browser input to support audio changes in Windows 10 20H1 * Fix for rare audio error when closing vMix.
23.0.0.57
* Added "Enable Notifiation Sounds" checkbox in Settings -> Audio This currently enables the Windows system defined "New Text Message Notification" sound when new chat messages are received for vMix Call * Fixed sound effect that could be heard after pressing enter in the vMix Call chat window * Fixed message appearing when opening Settings while Low Latency Capture was ticked * Fixed multi-channel audio handling in MultiCorder timeline.xml file * Transition duration was allowing 10000 even though 9999 is the maximum * Title presets with multiple lines would display incorrectly in right click Title menu * vMix Video Codec black/white levels will now display correctly in Adobe Premiere
 15 users thanked admin for this useful post.
stigaard on 5/30/2020(UTC), seb666 on 5/30/2020(UTC), ask on 5/30/2020(UTC), sinc747 on 5/30/2020(UTC), dunk on 5/30/2020(UTC), Osprey on 5/31/2020(UTC), STADIORADIO on 6/1/2020(UTC), Cris_AV on 6/1/2020(UTC), greggibson on 6/2/2020(UTC), MichelVRT on 6/3/2020(UTC), raugert on 6/5/2020(UTC), KnightHeart on 6/7/2020(UTC), GeorgeR on 6/14/2020(UTC), ayo on 6/21/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.58
* Added more disabling methods for Nahimic software which is hijacking vMix and causing errors * Fixed error with more than 48 thumbnails assigned to shortcuts for StreamDeck * Updated vMix Diagnostics to whitelist additional DLL files that do not cause issues * Fixed Input Position editing bug where pressing enter in a text box may cause it to no longer update. * Removed obsolete 24/7 label in Facebook Settings
ask on 6/22/2020(UTC), stigaard on 6/22/2020(UTC), doggy on 6/22/2020(UTC), AVStream on 6/22/2020(UTC), advisiontv on 6/22/2020(UTC), Chircanu on 6/23/2020(UTC), Simsyuk on 6/23/2020(UTC), bachnerfilm on 6/23/2020(UTC), dfritzke@ymcamke.org on 6/23/2020(UTC), sinc747 on 6/23/2020(UTC), raugert on 6/25/2020(UTC), John Barson on 6/25/2020(UTC), BETech on 6/28/2020(UTC), kayllastudio on 6/30/2020(UTC), talrmd on 7/4/2020(UTC), clafarge on 7/10/2020(UTC)
23.0.0.59
* Fixed issue where restarting some types of audio files was inconsistent. * Fixed issue where a Bus sent to Master would prevent Input Soloing from working correctly. * Improved performance on Add Input -> NDI and right click NDI Input menu where there are a very large number of NDI sources on network (>300!) * Fixed an issue where if an error occurred on starting a recording it may not report it correctly.
stigaard on 7/9/2020(UTC), DWAM on 7/9/2020(UTC), Simsyuk on 7/9/2020(UTC), elvis55 on 7/9/2020(UTC), Chircanu on 7/9/2020(UTC), raugert on 7/9/2020(UTC), BETech on 7/10/2020(UTC), avsoundguy on 7/10/2020(UTC), clafarge on 7/10/2020(UTC), ask on 7/10/2020(UTC), eduardocfs on 7/11/2020(UTC), userr777 on 7/12/2020(UTC), KnightHeart on 7/12/2020(UTC), greggibson on 7/12/2020(UTC)
