Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
On the first run of the vmix23.exe Windows Defender SmartScreen showed warning that the app is unrecognized. Just to let you know.
I know this thread is not for feature requests, but I just realized I forgot to request it before and it is kinda important. Would it be possible to show SRT streams status on top of the output window, same way currently Rec/Streaming/Ext is showed, red is good, yellow is bad.
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
I got the same windows defender warning, but it apparently installed ok
SRT BUG: Statistics report 0 Bandwidth, 0% packet loss, 0MB total data and 0ms RTT. Duration works fine.
Also, if I have statistics window open and start the SRT stream, the statistics window will not add the started stream automatically, I need to close the window and reopen.
An older version of SRT was accidentally included with the release version of vMix 23. This has now been fixed with the 23.0.0.31 update, so try that.
Note that it is expected the statistics will not auto update when changing inputs or settings, for performance reasons.
Originally Posted by: admin  An older version of SRT was accidentally included with the release version of vMix 23. This has now been fixed with the 23.0.0.31 update, so try that.
Note that it is expected the statistics will not auto update when changing inputs or settings, for performance reasons. Got it, will try out the update. 23.0.0.30 was running for about 4h, I do not know when exaclty, but after some time I got the message: https://prnt.sc/q9jx6n 1080p50 preset, mp4 looping in the output, one SRT stream output. Hardware Encoding and Low Power Encoder checked. GTX 980M. Statistics show 103235 Renderer dropped frames (about half an hour) for SRT Out 1 but Video column shows that SRT is connected. Video does not reach the server. Will try out the updated version same way and report back.
GT Title
Noticed a strange phenomenon: while there are several layer that animate from left to right in the designer (Scroll) once in vMix they go bottom to top instead Also when defining animation it appear i sometimes lose their settings after switching to other layers or items (say for Transition in ) and have to change to another animation trigger and back TranIn to get the settings back in view .
Update while writing , restarting the designer and opening the same file they have now the same effect as in vMix (animate from bottom to top )
it appears scroll setting is not preserved
Designer 2.0.0.27 vMix 23.34
Update: Direction in the Storyboard code is omitted when it should be left
Update 2 : Manually adding Direction="Left" to the code solves it for now
I try new 23 version and I cannot use old Title created! (file extension gtzip)!! Are they compatible or not?
Joined: 12/16/2018(UTC) Posts: 69  Location: Newfoundland & Labrador Thanks: 1 times Was thanked: 6 time(s) in 4 post(s)
Not necessarily a vMix23 bug, but still there. In GT Title Designer, EXPORT PNG shows cursor on graphic. See attached photos:  test2.png (40kb) downloaded 3 time(s). gt_bug_cursor1.jpg (276kb) downloaded 1 time(s).Originally Posted by: admin
Hi, if I export png file, this one is a static image and there are no editable text fields
Quote:Not necessarily a vMix23 bug, but still there.
In GT Title Designer, EXPORT PNG shows cursor on graphic. See attached photos: not if you get out of TextBlock editing/changing first ;-)
Originally Posted by: Uboz  Hi, if I export png file, this one is a static image and there are no editable text fields
Of course not , your exporting an image!! like a screenshot
I need to be able to edit text fields with connected db, not exporting png time to time
Originally Posted by: Uboz  I need to be able to edit text fields with connected db, not exporting png time to time While this is not the right part of the forum to ask how to do something as it not related to a bug in the software version, the advice is to look up (google) for some videos on how to design and use a title and how to connect titles to a Data Source Here is one but there are many more https://www.youtube.com/watch?v=t9CcKd9GeSY
Sorry, I've already created project and connected title with db in version 22, but now if I open project in 23 version it doesn't work.
Issues with playback speed when saving and reopening Presets.
I noticed this when in v23 opening a preset that was created in v22. One of the Inputs has a video loop with the playback speed set to 38%. In v23 the video does not play at all, and the playback speed is set to 0. Tried changing the playback speed, stop/start the player, and Change the Input by just selecting the same video again. Nothing seems to get the video playing again. (I could probably recreate the Input, but that means a lot of work as it is used in a few Virtual Inputs).
While trying to isolate the issue we found that creating a new Preset, adding an Input with the video, playing it in a loop in v22 - that Preset could be saved and opened in v23 just fine. We then opened the Preset in v22, changed playback speed to 38&, saved the Preset and exited. When opened again in v22 it plays at 100%, same thing (100%) if opened in v23.
Side note, I cannot find any info in the Help about the right-click option "Show/Hide Playback speed".
Hi Richard,
I have followed these steps and am unable to replicate the issue, the speed is loading correctly from file in both versions. There have not been any changes to the playback speed functionality at all in 22 vs 23, so maybe it is something strange to do with that particular file.
Also, make sure 22 is not installed side by side with 23 as they are not compatible, only one version should be installed on the machine at a time.
Martin vMix
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
we find that in some times the audio follow video not work, we have the same issue in two .38 ,and the input leave program and still is on
A GT issue: I noticed that when an object (e.g. a rectangle) is bounded with extra padding to a TextBlock, the object's padding is still visible when there is no text in the TextBlock. I believe this is an unwanted behaviour. In my case for a two-line subtitle, whenever one or both text lines are empty. /richard
p.s. thanks for the update 23.0.0.37 that fixed the playback speed problem!
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi, I've discovered a bug today : when the audio peaks in the master bus, the fullscreen multiview changes layout... Here is a video : VMIX BUG VIDEO
