jen777
#1 Posted : Wednesday, December 11, 2019 1:43:40 AM(UTC)
jen777
Ukraine
I'm developing FUL HD captions with CSS and WebGL animations using real time data with Web Browser rendering input with vMix.
Could you guide me how I can enable GPU acceleration and WebGL support at chromium browser and use latest version of headless chrome for web pages rendering?
Right now my web browser animations are run on CPU and takes 20-30% of CPU load on latest i9 CPU.
Maybe you can create and update for this request or you can build custom release with these set of changes for me?
Thank you very much and appreciate your work and vMix product.
richardgatarski
#2 Posted : Wednesday, December 11, 2019 6:01:04 AM(UTC)
richardgatarski
jen777, could you describe what kind of captions/use case? I might have an alternative approach. PM me if you want.
jen777 on 12/11/2019(UTC)
jen777
#3 Posted : Wednesday, December 11, 2019 6:22:41 AM(UTC)
jen777
Ukraine
Thank you. I have sent PM to you with more details.
richardgatarski
#4 Posted : Wednesday, December 11, 2019 6:20:21 PM(UTC)
richardgatarski
+1
I leave it up to the vMix team to comment upon if your request is technically possible.
Meanwhile, a workaround (for non-transparent animations) might be used in your case. Add a capture device to one of your PC's display outputs, run your web browser in that display, and input it as a camera in vMix. Cheapest capture device could be the Elgato CamLing 4K, but it sometimes does not like PC resolutions. So probably the Yuan PD570 is a better low cost alternative. The Magewell USB Capture devices would definitely work, albeit a little bit more expensive.
Llorx
#5 Posted : Saturday, January 11, 2020 11:27:10 PM(UTC)
Llorx
+1
When I want to load a WebGL 3D map it don't works.
