Recently I use vMix to create copies for the RTV market regulator. I record the NDI source and the program creates new files every 30 minutes. The problem is that they have the same name as the previous ones, only the last number changes. Is it possible to add a function in the form of a bird that would change the time to the current one when creating each new recording file?
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Would :
Settings-> recording -> Filename Format -> {0} - {1:dd MMMM yyyy - hh-mm-ss tt}
help ?
I know these functions from the inside out. The problem is that until it turns off recording and restarted, the date in the clip name will not change. Only the new number at the end will be added.
Yeah , just noticed it myself , sorry
Guess for now the option is to rename the files (batch) with the creation dates added to the filenames as those do change
Nothing happened :) For now it is a solution. I used to do Adobe Flash Media Live Encoder, but it consumed a lot of resources. There was an option to split files with a new name containing the date.
