No sound via a capture card (SOLVED)
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hi all, I can't get any sound via the AverMedia HD Capture C985 mic input on the card into vMix (22.0.0.69 x64)!
Any ideas please?
Figured it out, for those of you who might have the same issue.
Select Pro mode in RECentral, then go to 'Audio Source', use the drop down and select 'Audio In'. Press 'Ready' and then Save.
That's it, you should have audio input in vMix.
