Manny Sangha
#1 Posted : Thursday, December 5, 2019 4:38:39 AM(UTC)
Manny Sangha
Canada
We have requirement for additional HD/SDI outputs.
Is it possible to make software flexible to support input and output based on number of I/O Cards? Since rendering is happening on the card it should not tax the system?
If not flexible, can it be made to support more than 2 HDSDI outputs?
Is it possible to have Aux bus (another switchable outputs)? These feeds are used for monitors in show that are switched during the show.
Thanks,
Manny
sinc747
#2 Posted : Thursday, December 5, 2019 1:45:38 PM(UTC)
sinc747
+1
#3 Posted : Thursday, December 5, 2019 3:30:08 PM(UTC)
Hi Manny,
Do you want all the outputs to show all something different?
If not, then I would recommend using just the External 2 output in vMix and using a splitter router to duplicate that signal
as trying to duplicate from the computer is going to use a huge amount of system resources and is not all that practical.
Manny Sangha
#4 Posted : Friday, December 6, 2019 2:35:08 AM(UTC)
Manny Sangha
Canada
We are thinking of having them as different outputs for each monitor on the show. For example : One monitor would be graphic and other could be person on skype or source from internal video router for interview. During the interview, monitor can switch to clip of subject they are talking about.
The Blackmagic Quad 2 has 4 outputs. Is it possible for using in this fashion?
We are trying to use this product in Broadcast station.
Thanks,
