If title includes an image field, this can also be assigned to a data source.
For example c:\vmix\picture\ball.png
this is full path.
Can it be a relative path?
I'm sure I've seen UTC in the past and used relative paths when changing images, but I didn't succeed.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
If you mean relatie to a local location you can set the title datasource connection to c:\vmix\picture\{0} or alike
PS pointless to post the same question in 3 separate forums !!
Originally Posted by: doggy  If you mean relatie to a local location you can set the title datasource connection to c:\vmix\picture\{0} or alike
PS pointless to post the same question in 3 separate forums !! Thanks~~!
