Joined: 10/7/2019(UTC) Posts: 19  Thanks: 5 times Was thanked: 3 time(s) in 2 post(s)
I think there is a problem in vMix with Blackmagic card. Both in vMix 22 and 23 I am using PC-1 Blackmagic card as an input to vMix And sending vMix out to Blackmagic card as an external device. All in 1080 50i PC-2 SDI in Blackmagic card The problem is, outputting blackmagic input thru vMix external SDI output Makes the video a bit soft, And it is 1 video line lower than it should be. Compered to blackmagic media express pass thru Of the same input and output. On more interesting fact, The NDI output of the SDI source input from vMix (Additional NDI Outputs) Is perfectly fine! the NDI of the Main output is also soft..  Good AND BAD 4.png (841kb) downloaded 2 time(s). 1 BAD- PC-1 SDI to vMix input, SDI out From vMix external to PC-1 Media express SDI in.png (1,570kb) downloaded 4 time(s). 2 Good - PC-1 Media express SDI in - to PC-2 SDI in Media Express.png (1,536kb) downloaded 1 time(s). 3 Good -PC-1 SDI in to vMIX, vMix NDI Additional NDI out put to PC-2 Studio Monitor recording NDI stream.png (1,871kb) downloaded 3 time(s).
