Behringer X32 and VMix Question
Rank:: Newbie
Trying to figure out the best way to do the following (if at all possible).
1. Utilize X32 as an input for the system. (easy-just plug and play) 2. Route the output of vMix from vMix call back into the board. 3. Utilize x32 and the separate buses/outputs and other inputs to create an IFB of sorts for utilization between director, talent, and callers if at all possible.
Not sure, but scoured the internet enough and can't figure it out, so I figured I would reach out to you all.
About us - high school production group/class for live sports, announcements, and more.
Thank you,
I've done ALL of that with an X32 in the past.
Connect the X32 to the PC via vMix and you can pretty much use the X32 as a massive soundcard for vMix, ins and outs.
Unfortunately it's something you have to work out.. the x32 is a very very powerful system and is complex to program. In fact, so complex I sold it.
But once you get it working, it works very nicely..
Joined: 2/21/2018(UTC) Posts: 4   Location: North Hollywood, CA Was thanked: 2 time(s) in 2 post(s)
I actually have an X32 and found the same issue. The problem is that vMix doesn't have enough audio busses out and it also doesn't offer Direct Outs for the different sources. If you only have 1 or 2 callers you can use the A bus and B bus to output to the X32. If you want to use more than that or you want to have multiple video playbacks you wont have enough outputs for that either. It looks like Version 23 of vMix will address some of that with a lot more Bus outs. I still wish there was a direct out for all the sources but for now the added Busses should help. You can try the Beta, but it IS a beta so I would heavily test it before you put it into critical production.
