Facebook Stream Stops after 2 Mins
After I updated the application to the latest version. When streaming to Facebook, the stream begins and stops streaming within 2 mins. The stream button turns amber and starts flickering. Anyone have a fix?
Typically when the Stream button turns amble it means that vMix is streaming data faster than your internet connection can accept it. It can also mean that the CDN is having an issue receiving the stream.
Click the Stream setting cog and then click "View Status." This will show you the stream log. You might post some of that here and we can try to determine the cause.
- Tom
Tom Thanks for the information. I experienced the same problem yesterday, while trying to stream our church worship service. I have been streaming the services for two years and never had this problem. I will provide the logs as you suggested.
Same issue here, how do you guys fix it pls?
