sam602
#1 Posted : Sunday, October 27, 2019 12:02:15 PM(UTC)
sam602
Trinidad And Tobago
I ran another test using two different config pc.
PC1:Only had 8meg internal mem and Nvidia 630 card. I experienced and confirm that the video was sticking while the audio continued..I believed someone mention this was happening earlier.The stream was set to H264 6 meg AAC 128.
PC2:This pc had 16meg internal Nvidia 640. Video was run using the same specs. The results was quite different. It was clear..smooth colors and no sticking.
This is just my observations
#2 Posted : Sunday, October 27, 2019 12:36:35 PM(UTC)
Was thanked: 4765 time(s) in 1636 post(s)
Is this with or without hardware encoding and/or decoding enabled?
Note that old graphics cards can struggle with either of these.
sam602
#3 Posted : Sunday, October 27, 2019 2:02:10 PM(UTC)
sam602
Trinidad And Tobago
Hardware encoding and/or decoding is enabled
serge-tv
#4 Posted : Wednesday, October 30, 2019 4:43:26 PM(UTC)
serge-tv
Ukraine
Hi! Nearly the same situation-
Hardware encoding is DISABLE.
Output1 is in SRT Listen mode. Encoding to H264.
When CPU using increasing to 70% or more SRT streaming stoped. Then (after 5-10 sec.) Stream renewed but only audio.
When stop/start SRT all became fine till next using CPU over 70%
sam602
#5 Posted : Friday, November 1, 2019 1:58:34 AM(UTC)
sam602
Trinidad And Tobago
After updating to latest beta version 23.0.0.22.. Passphase still not working in Wowza Streaming Engine... Cantinue to consult with support.
Speegs
#6 Posted : Friday, November 1, 2019 2:27:28 PM(UTC)
Speegs
Not super helpful, but the Vmix Passphrase does work with a different streaming server. Any information can be helpful when solving a problem.
sam602
#7 Posted : Friday, November 1, 2019 11:56:19 PM(UTC)
sam602
Trinidad And Tobago
This response appears to be a myopic view. When you consider the install base of WSE and the benefit to vMix to get this right compared to the ones you refer too. There is also the fact that Wowza is half of the group that put SRT out to the open source community. In any case I am fully aware that the passphase works in other server platforms. This is not to put down the others platforms,and I acknowledge vMix maybe more up to date. Therefore I hope this is resolved soon.
Similar Topics
SRT Testing, Audio Encoder bitrate (SRT)
by ashjmckenzie 11/5/2019 4:31:56 AM(UTC)
