Systems
Will Vmix run with Radeon™ RX Vega M GL graphics
Joined: 10/26/2019(UTC) Posts: 2   Location: Hjoerring
Greetings, We local soccer club that's about to upgrade in near future to vMix for livestreaming soccer events and we got our eyes on a PC system from INTEL® called NUC KIT NUC8I7HNK. This Graphic system that's within NUC KIT NUC8I7HNK is a Radeon™ RX Vega M GL graphic card. Can vMix still use this as a Graphic card, or does vMix only work with Dedicated Nvidia Cards? With best regards, Fortuna Hjoerring! http://www.fortunahjorring.dk
Joined: 3/20/2019(UTC) Posts: 31  Location: San Diego Was thanked: 3 time(s) in 2 post(s)
It will run, but all the encoding will be done by the CPU.
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
we tested VMIX 22 and yesterday VMIX 23 SRT on exact these Systems,NUC KIT NUC8I7HNK, and where disappointed from the results. VMIX does not support the GPU renderer from the embedded CPU. Acting as SRT Server or as Camera VMIX System does work well, also playing HD video files. as soon you will record larger formats or stream, the performance drops dramatically. 4K playback is impossible. The M2. Card from Blackmagic (1 x IN/OUT HD) works perfect in HD 1080i25.
Joined: 12/7/2017(UTC) Posts: 47 Location: New Zealand
Thanks: 4 times Was thanked: 4 time(s) in 4 post(s)
We have one of these systems and it works very well. We use for small/medium events with up to 3 cameras and one external output via a thunderbolt connected Blackmagic Duo2 card in an Akitio box. The trick with regards to performance is to enable mp4 recording using the Hardware Encode option available in the mp4 recording page. The engagement of the recording seems to kick the GPU into life and performance is then very good for such a small footprint system. We have also used this system to test SRT with version 23 and again this has worked very well so far.
 1 user thanked nakedeye for this useful post.
Thank you all for the input
It given us something to think about.
Systems
