Joined: 7/17/2017(UTC) Posts: 17   Location: Singapore
Most good graphics card has 4 (or even more) outputs. Can we have more than 2 fullscreens?
Very often I find myself in a situation where 1 for PC display, 1 for mutliview, 1 for program output/LiveU and 1 for specific Input.
Regards Michael Koh
A solution for this is to use a Birddog MINI. Using vMix 4k or above, you set output 1-4 to your preferred source. Set the MINI in decode mode (or after today's FW release encode and decode) and select the NDI source from vMix you want to display. Connect the MINI to your additional display.
 2 users thanked ask for this useful post.
+1 for the extra screen output, could be usefull when you use vmix as a replay platform...
Rank:: Member
Joined: 8/30/2019(UTC) Posts: 11  Location: Farum Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Forum Rank:: Member
Joined: 6/5/2019(UTC) Posts: 29  Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
+1 ... (NDI will suck a lot of CPU power in comparison to a gpu solution)
Joined: 8/2/2013(UTC) Posts: 1,113   Location: Fairhope, Alabama USA Thanks: 607 times Was thanked: 207 time(s) in 173 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Joined: 12/16/2018(UTC) Posts: 69  Location: Newfoundland & Labrador Thanks: 1 times Was thanked: 6 time(s) in 4 post(s)
+1
Can never have too many monitors.
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 178 times Was thanked: 3 time(s) in 2 post(s)
This was requested many times before, and the explanation Martin did give in the past was that it is very difficult to get extra fullscreen outputs because of timing issues that arise. I do agree it would be great to have, even if it would only be one extra, but with a not too expensive extra system, you can get 4 NDI outputs extra for cheap. The hardware NDI products also are interesting, I like the lower priced Birddog mini, a great camera solution to get the signal to vMix and send a return video at the same time, but if you only need outputs, building a system for the same money gets you 4 outputs instead of only one. It is time the Chinese get involved with NDI. ;)
Originally Posted by: Mathijs  It is time the Chinese get involved with NDI. ;) In case you hadn't noticed, some of them already are...  20190910_122825csl.jpg (47kb) downloaded 14 time(s).
Well, Magewell is not a Chinese price warrior to me. They make decent products that are not overpriced, but not cheap either. For 2K to add 4 outputs to my system, I will still choose to build a system for it for a fraction of the cost.
Thanks: 2 times Was thanked: 10 time(s) in 9 post(s)
+1 from me, hope Martin can find a way to use more/ all available outputs on the gpu.
Joined: 10/25/2018(UTC) Posts: 43  Location: Moscow Thanks: 8 times Was thanked: 4 time(s) in 3 post(s)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
you can grab a monitor that has a loop output if you just need to duplicate one of your screens in a different area of the studio then you've still got one free
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
+1 We routinely use 4 outputs simultaneously, which currently requires NDI players or streaming players (with latency). Additional fullscreen outputs from the GPU would be very useful.
