66 Pages«<3738394041>»
kevev
#761 Posted : Tuesday, October 22, 2019 7:44:13 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Originally Posted by: elgarf Go to Quoted Post
@kevev, not sure it will be such useful =( Btw, I'll think about it. Maybe there will be helper for scripting.
@curtismacd31, good to know you found solution. Scripting is also possible, but solution with list widget is simplier.
Thank You Elgarf for the help.
Any progress on the zero(0) issue?
Also is there a way to use Windows shortcut paths? ex: %USERPROFILE%\Desktop\folder\image.png
2019-10-21 16:48:07.6642 INFO Trying to send function <Function=SetImage&Value=%25userprofile%25%5cDesktop%5cSaturday+Showcase_assetBank%5cSettings%5cLower_3rd_scoreboard%5cLowerBar_scoreBoard_GT_Animated_v1.2_2019%5cTimeOuts_0.png&Input=1afcdc93-5b48-4bc1-bf0d-5da7471add6b&SelectedIndex=0> in async mode.
2019-10-21 16:48:07.6839 INFO Function URL is <http://127.0.0.1:8088/api?Function=SetImage&Value=%25userprofile%25%5cDesktop%5cSaturday+Showcase_assetBank%5cSettings%5cLower_3rd_scoreboard%5cLowerBar_scoreBoard_GT_Animated_v1.2_2019%5cTimeOuts_0.png&Input=1afcdc93-5b48-4bc1-bf0d-5da7471add6b&SelectedIndex=0>.
2019-10-21 16:48:07.7229 ERROR Error while sending async function. System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
elgarf
#762 Posted : Tuesday, October 22, 2019 1:27:09 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@kevev, zero issue is fixed, I push update bit later.
I'll check shortcuts paths, not sure they are supported by vmix, but I can unfold then on UTC side.
kevev
#763 Posted : Tuesday, October 22, 2019 1:35:31 PM(UTC)
kevev
Awesome! Thank You very much.
elgarf
#764 Posted : Tuesday, October 22, 2019 6:05:28 PM(UTC)
elgarf
Russian Federation
@kevev, check this.
Download
@chococrisps35, I've also added colorizing entrie button as option.
kevev
#765 Posted : Wednesday, October 23, 2019 12:44:09 AM(UTC)
kevev
@kevev, check this.
Download
My hero! I will download today.
JAIRODJ
#766 Posted : Wednesday, October 23, 2019 1:37:35 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi @elgarf
I imagine that it is a small detail of typing, in the version of the UTC says (10/17/2019)
in the publication is 22/10/2019)
elgarf
#767 Posted : Wednesday, October 23, 2019 10:00:52 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, hmm. Looks like that was my fault(
I've replaced with the same download link.
kevev
#768 Posted : Wednesday, October 23, 2019 12:02:50 PM(UTC)
kevev
Zero is working. Thank You Elgarf.
curtismacd31
#769 Posted : Wednesday, November 13, 2019 4:58:56 AM(UTC)
curtismacd31
@elgarf do you have an example of how the scripting could work? What I would like yo do is have a roster list as an external data source, then when I select either the player number or player name the other dropdown field populates with the correct information. Then I would like to do a concatenate to put that data together and feed it to the title in vMix.
elgarf
#770 Posted : Monday, November 18, 2019 9:42:06 PM(UTC)
elgarf
Russian Federation
@curtismacd31, hmm. Now I think it's a bit complex. Why you need several lists, instead of one in table mode?
I think, I can make "link" mode to sync selected items between two lists, but not sure it's necessary.
Le-bo2d9
#771 Posted : Friday, November 22, 2019 8:22:14 PM(UTC)
Le-bo2d9
I have a textfield linked to a title field.
The tilte is linked to a datasource.
I control the datasource with 2 buttons (up/down).
The title fields are updated but the textfield is not updated automaticly, the field is updated when I do a sync.
Is there a way to get the update automaticly?
Kind Regards
Koen Deschepper
Le-bo2d9
#772 Posted : Friday, November 22, 2019 8:34:25 PM(UTC)
Le-bo2d9
I found the solution.
On the button to select the line in the datasource i added a second script with the "updatestate" commando
elgarf
#773 Posted : Saturday, November 23, 2019 7:33:39 PM(UTC)
elgarf
Russian Federation
@Le-bo2d9, hi. That's good solution)
UTC doesn't make sync too much times, because I thought it's bad for performance. Btw, state dependent buttons ruins it😪
郭子涵
#774 Posted : Saturday, November 30, 2019 10:47:32 PM(UTC)
郭子涵
China
If title includes an image field, this can also be assigned to a data source.
For example
this is full path.
Can it be a relative path?
I'm sure I've seen UTC in the past and used relative paths when changing images, but I didn't succeed.
elgarf
#775 Posted : Wednesday, December 11, 2019 7:17:16 PM(UTC)
elgarf
Russian Federation
@郭子涵, I thunk vMix does not recognize relative paths =(
Btw, I've pushed update with global variables (you can use them in expressions).
JAIRODJ
#776 Posted : Friday, December 13, 2019 5:28:07 AM(UTC)
JAIRODJ
Hi, on the date of the version says 6/12/2019, the version of the publication says 11/12/2019.
it must be the change in the text nothing more.
I have tried to use the global variable, I did not manage to do it.
Please could you explain how to use it.
Thanks and success.
thanks 1 user thanked JAIRODJ for this useful post.
djlyds on 12/13/2019(UTC)
djlyds
#777 Posted : Friday, December 13, 2019 9:06:59 AM(UTC)
djlyds
Can someone help me to be able to name the films auntomatically from utc?
elgarf
#778 Posted : Friday, December 13, 2019 11:26:23 PM(UTC)
elgarf
Russian Federation
@JAIRODJ, it mostly for API function.
For example, you can add IP variable, and use it in the script:
IP+'/API?Function=QuickPlay'
Where IP is 192.168.0.5:8088
So, if you have many buttons with draft api calls to another machine, you don't need change value in every script. I'm thinking about replacing some pattern to variable value in lists (so you can save directory path to variable, and change it for all strings in one place).
@djlyds,
You want put in the title name of playing now file, right?
djlyds
#779 Posted : Monday, December 16, 2019 9:14:46 AM(UTC)
djlyds
@djlyds,
Exactly that I want to do but I can not find the way to do it would be kind to tell me how it is done.
JAIRODJ
#780 Posted : Tuesday, December 17, 2019 9:55:46 AM(UTC)
JAIRODJ
@elgarf
I understood, I thought it was something similar to setvariable but I could use the variable inside UTC and call it from another widgets
Guest (13)
