Joined: 10/11/2019(UTC) Posts: 1  Location: Toowoomba Was thanked: 1 time(s) in 1 post(s)
Some improvements I'd like to see in the TCP API -
* JSON output of status (much like current XML) * To be able to change filename and settings for Recorders through the API * To be able to change streaming settings through the API * Perhaps add a 'verbose' mode where Function name is returned in the return string - make it easier to know which command has executed when multiple sent
I'd also like to see a mode where vMix can be started as a service and be controlled solely through the API
kind Regards Warren Hedges
 1 user thanked wazza for this useful post.
