Feature Requests
Remove Audio Input from Video Inputs
Joined: 12/12/2018(UTC) Posts: 23  Thanks: 1 times Was thanked: 8 time(s) in 6 post(s)
I have videos that don't have audio with them, and will never have audio to be played when it is playing. It would be great to completely remove that audio input from the Audio Mixer (not just collapse it). Keep the audio mixer cleaner.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
+1 big yes, always having to search for audio inputs and only need 3/4
Agreed! And from NDI sources...
Ben
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Actually, I would like to have this option for other Input types too (eg Cameras, and NDI).
How about renaming this request to "Disable audio functionality for Inputs"? And suggest implemented as a new option in the Input's setting (cog wheel).
misread the first time +1 any input not just the video example
You have been a member since:: 12/14/2018(UTC) Posts: 160   Location: Clermont-Ferrand Thanks: 35 times Was thanked: 9 time(s) in 8 post(s)
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Joined: 3/12/2019(UTC) Posts: 22  Location: Hamburg Was thanked: 3 time(s) in 3 post(s)
Joined: 10/9/2018(UTC) Posts: 28   Location: Leesburg AL Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
+1 YES PLEASE! Maybe just add a check box in the settings to active audio?
+1.5 drop down menu to select the input of another camera or the option of none
Joined: 10/9/2019(UTC) Posts: 40  Location: Bålsta Thanks: 2 times Was thanked: 5 time(s) in 2 post(s)
+1
Use a lot of web cameras and their audio is usually crap so would be splendid if (16+ in my case) garbage audio channels could be removed and spare some cpu too. and also the other way around. if pushing audio thru say sdi without video(black). remove the video completely and free up some of those cycles
This feature has been added in 22.0.0.66. The original idea was to keep the audio mixer clean. The audio settings now has a "Visible in Mixer" checkbox to hide unwanted audio inputs. https://forums.vmix.com/...t18200-vMix-22-Changelog > "* Added ability to hide an individual input's audio mixer if it is not needed."
 1 user thanked cookdoeyl for this useful post.
Hallo,
Add Input - Camera - Camera: Webcam, Audio Device: None.
Originally Posted by: cookdoeyl  This feature has been added in 22.0.0.66. Nice! didn't notice that on my last update but have to take a look again. Guess this thread can be set to resolved
Feature Requests
