SeeSam
#1 Posted : Wednesday, October 9, 2019 4:50:30 AM(UTC)
SeeSam
Denmark
Hi
When doing fast pace sports and doing replay for thous events, i often find the need to be able to find a replay clip fast again,
i would like a shortcut to be able to hit one key on the keyboard or a x-kays to tag a clip like "Round 5" and then hit another key to tag "Knok out"
in fast pace sports like boxing it is nearly impossible to tag events with the current system, and it is nearly impossible to find the right clip in a short break between rounds...
so please add "ReplayNameSelectedClip" and "ReplayNameLastClip" to the shortcut functions,
Thank you...
Barney Box Lane
#2 Posted : Wednesday, October 9, 2019 8:43:10 PM(UTC)
Barney Box Lane
Hi you can add pre selected tags like that already, enter the tag name into the value of the shortcut
SeeSam
#3 Posted : Thursday, October 10, 2019 5:59:54 PM(UTC)
SeeSam
Denmark
Thank you, i know of, and use the permade tags,
only problem is that they are way too slow, when you have to let go of the keyboard, select the clip, use the drop-down menu, tag the clip with round number, and an action of what happens in that particular clip, then either tag the next clip or get back to work, when one keyboard press would tag that clip with a round number, and another keyboard press to tag that it was a "nice sequence" or a "knockout".
#4 Posted : Thursday, October 10, 2019 6:56:31 PM(UTC)
sam not see
SeeSam
#5 Posted : Thursday, October 10, 2019 10:10:12 PM(UTC)
SeeSam
Denmark
will try to see as soon as i am home...
Thank you :)
ralston
#6 Posted : Wednesday, October 16, 2019 7:05:43 AM(UTC)
ralston
and did that work out for you ?
ralston
#7 Posted : Wednesday, October 16, 2019 7:10:58 AM(UTC)
ralston
Since your into Replay using Vmix can you advise me on the best format to record that would give me frame by frame IN/OUT precision. I am an editor and would like to easily go back a few frames in the action and update the IN point with that new value. I cant seem to get the hang of sliding the value within the event its self. We currently dont have a outboard controller, looked at a few recently at IBC but hav't currently got the budget to move forward with one. using the mouse is next to useless. So a simple nudge back and mark IN would be great !
#8 Posted : Wednesday, October 16, 2019 7:52:24 AM(UTC)
Shortcut: ReplayJumpFrames
ralston
#9 Posted : Thursday, October 17, 2019 12:21:06 AM(UTC)
ralston
thanks for that Doggy but I am looking for a way wage IN position is updated to the NEW event can be allocated to a different bank so not played back immediate.
Simply a way of nudging the IN / OUT points of the clip.
#10 Posted : Thursday, October 17, 2019 12:47:15 AM(UTC)
Well i though my english was reasonable but guess not as i have no idea what you exactly want.
nudge: ReplayJumpFrames
Mark In : ReplayMarkIn of ReplayUpdateSelectedInpoint
wage?
"to the NEW event can be allocated to a different bank" ?
You want (guessing) to create a new event of an existing event where you nudged the in/out points now ? then just copy the event (right click the event, fyi just found out this by just trying) and nudge away (wow there is even a shortcut for that)
Yes , was the initial answer not correct then ?
ralston
#11 Posted : Thursday, October 17, 2019 1:22:27 AM(UTC)
ralston
ReplayUpdateSelectedInpoint seems to work ! perfect thanks !
ElBurrito
#12 Posted : Thursday, March 16, 2023 8:59:54 AM(UTC)
ElBurrito
By tagging are y'all talking about just renaming a clip or is there actually some tagging function I'm unable to find anywhere?
Guest (4)
