Troviss
#1 Posted : 11 years ago
Troviss
I have found a way to create a good looking virtual set, but can´t get it perfect. I add a photo as a new layer and after that I even put in a desctop capture from a Powerpoint information. All is working fine but I can´t get a good perspektive for the text in the top and bottum. Is there any possibillity for you to give us that funktion, to get a better perspektive looking? If we can make one side little lower in the top and bottum it must work fine. The set I use is "Contemporary Studio". I try to show the power point on the right wall over my left shoulder.
Is there any possibility to make the PowerPoint presentation a little bit lower on the left ore right side? If there is no function for that in vMix, can you tell of I can get that in PowerPoint ore in some other plugin?
