Janne Adolfsson
#1 Posted : Wednesday, October 2, 2019 6:32:17 PM(UTC)
Janne Adolfsson
I need a mirror flip output for our teleprompter.
Running on NDI output...
#2 Posted : Wednesday, October 2, 2019 6:59:53 PM(UTC)
a virtual set with a mirror flipped UVmap will do the trick
Janne Adolfsson
#3 Posted : Wednesday, October 2, 2019 8:21:32 PM(UTC)
Janne Adolfsson
Yes, but you need another software, i can't see that it can be done in vMix...
#4 Posted: : Wednesday, October 2, 2019 10:07:08 PM(UTC)
Why would you need other software and virtual sets are possible in vMix and they can contain UVmap !
Here you are
flipuvmap.zip (3kb) downloaded 128 time(s).
thanks 4 users thanked doggy for this useful post.
Janne Adolfsson on 10/3/2019(UTC), AndrewRed on 10/3/2019(UTC), smudge1977 on 5/14/2020(UTC), billh2020 on 12/31/2020(UTC)
Janne Adolfsson
#5 Posted : Thursday, October 3, 2019 1:12:03 AM(UTC)
Janne Adolfsson
Here you are
Solved it!!!
Thanks Doggy!
Please move this post to "Tip and trix"
#6 Posted : Thursday, October 3, 2019 1:16:47 AM(UTC)
Your welcome
But next time check your original posting for any given answers before creating another post (now deleted) saying you cant resolve your problem !
zenvideo
#7 Posted : Thursday, October 3, 2019 1:33:34 AM(UTC)
zenvideo
Just for the record, whilst we're on the subject of NDI output for teleprompting displays, if a hardware NDI to HDMI decoder is required, the Magewell Pro Convert unit includes both Vertical and Horizontal image flipping functions in its Web GUI.
#8 Posted : Thursday, October 3, 2019 1:58:24 AM(UTC)
Another for the record
The new Studio Monitor ( NDI 4) also can display both Vertical and Horizontal image flipping
nowski on 2/10/2021(UTC)
nowski
#9 Posted : Wednesday, February 10, 2021 10:03:22 PM(UTC)
nowski
Thats a fab solution, I have just been trying to figure this out myself, sending the multiview to a low cost teleprompter so I can keep my eyeline while presenting/producing.
What I did was install Duet - which lets me send a screen to an iPad - yes works on PC too.
So I capture VMIX UI into local dekstop input then just send that over NDI via one of the four outputs to Studio Monitor and flip the video then put that window onto the Duet display. Viola! It does nudge the GPU up a little but so far so good.
Only issue being if I need more outputs (I often use 3+4 for vmix call ISO records), but I'll figure that out when I can.
Guest (4)
