MichaelKoh
#1 Posted : Tuesday, October 1, 2019 10:56:59 PM(UTC)
MichaelKoh
Singapore
This function does not seem to work on an audio file anymore. I have to use SetVolume without the fading effect. However, it is still working on an AudioInput input.
#2 Posted : Tuesday, October 1, 2019 11:05:08 PM(UTC)
Was thanked: 4736 time(s) in 1625 post(s)
Hi Michael,
Double check the shortcut has been configured correctly.
I just tested adding an MP3 file and setting up two shortcuts:
1. Value set to 100,1000 (go up to 100% taking 1000 milliseconds)
2. Value set to 0,1000 (go down to 0% taking 1000 milliseconds)
While playing the audio file I pressed the two shortcuts and the volume
faded up and down as expected.
MichaelKoh
#3 Posted : Tuesday, October 1, 2019 11:14:09 PM(UTC)
MichaelKoh
Singapore
I am sure the shortcut is correct. When I change the function to setvolume and value to 0, it works.
ggudnason
#4 Posted : Tuesday, October 1, 2019 11:20:38 PM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
I have had the problem that setvolumefade stopped working for an input and also asin a trigger. The only way to get it to work was to change the input. And selecting the same audiofile I was working with.
#5 Posted : Tuesday, October 1, 2019 11:25:13 PM(UTC)
Note that SetVolumeFade requires two parameters not one as is the case of SetVolume.
It requires a volume *comma* then the milliseconds. If one of both of these are missing it will not work.
talrmd on 4/22/2020(UTC)
MichaelKoh
#6 Posted : Tuesday, October 1, 2019 11:55:01 PM(UTC)
MichaelKoh
Singapore
I have screen captured how the shortcut works on my audioinput but when I change to a mp3, it does not work. I have been using this feature for quite a while. After .68 patch, it stopped working. I am using .69...also not working.
#7 Posted : Wednesday, October 2, 2019 12:39:11 AM(UTC)
Try converting the audio file to WAV or trying a different MP3 and see if that helps.
In .68 we added a fallback audio decoder in the case where some MP3 files would not play using the default Windows decoder.
The fallback decoder does not currently support SetAudioFade so that might explain it.
D.R. Lynn
#8 Posted : Sunday, August 2, 2020 8:31:43 AM(UTC)
D.R. Lynn
trying to use SetVolumeFade with a stinger, doesn't work at all
tried it with Triggers on 2 video clips, cutting between the two, still nothing
Ideas?
dpinka
#9 Posted : Friday, February 26, 2021 4:49:50 AM(UTC)
dpinka
For whoever stumbles across this. It turns out that SetVolumeFade works with a period when fading in (100.3000). But only the comma works for fading out (0,3000). Funny quirk but fixed it for me.
on_call
#10 Posted : Sunday, April 11, 2021 2:23:18 AM(UTC)
on_call
Can anyone provide an example script for a "setvolumefade" function? I'm using the vMix Script Builder app and have had some success. (p.s. "Background" is the name of my background music input)
This works fine (of course the duration value does nothing):
Function=SetVolume&Duration=1000&Input=Background&Value=100
But this doesn't work at all:
Function=SetVolumeFade&Duration=1000&Input=Background&Value=100
And this is a great script that I found here, which works for fading down an audio input:
Dim doc As New XmlDocument()
dim bgmi = Input.Find("Background")
doc.LoadXml(API.XML())
Dim node As XmlNode = doc.SelectSingleNode("/vmix/inputs/input[@title='Background']")
Dim volume As Integer = node.Attributes.GetNamedItem("volume").Value
Console.WriteLine(volume)
Do While volume > 0
bgmi.Function("SetVolume", volume)
volume = volume - 1
sleep(10)
Loop
Any guidance would be appreciated. I'm trying to find a way to Fade Up audio, as this custom script works for now...but a reliable way to SetAudioFade would be ideal. Thanks.
thanks 1 user thanked on_call for this useful post.
ryanlehms on 4/27/2021(UTC)
#11 Posted : Sunday, April 11, 2021 2:54:38 AM(UTC)
it's a good idea to check the helpfile's shortcut function references https://www.vmix.com/hel...utFunctionReference.html or even the shortcut details (settings) when creating one as it clearly explains what is needed and how
SetVolumeFade:
Set volume gradually over x milliseconds.
Value = Volume 0-100,Milliseconds
Then it will work perfectly
If still not : Value is the volume to go to comma the duration
The script was created before the function was available !!
raugert
#12 Posted : Wednesday, April 14, 2021 12:26:37 AM(UTC)
raugert
Canada
@on_call
The following command will fade up Input named Background to 100% over 1000 milliseconds (don't put anything into Duration)
Function=SetVolumeFade&Input=Background&Value=100,1000
The following command will fade down Input named Background to 0% over 1000 milliseconds (don't put anything into Duration)
Function=SetVolumeFade&Input=Background&Value=0,1000
