katalizt
#1 Posted : Saturday, September 28, 2019 3:50:19 AM(UTC)
katalizt
Views messages in topic : 10
When I create a vMix Call and choose None for the return feed to the guest, it still sends out my main output as a return feed. The right click menu on the input shows None is selected for the video feed. These options aren't working, I cannot turn off the return feed.
I want to turn this off as we are using vMix call essentially as a remote camera and the operator does not need the return feed.
sinc747
#2 Posted : Monday, September 30, 2019 1:36:20 AM(UTC)
sinc747
I have a similar experience. When I start a video call with the return feed set to NONE, then change to OUTPUT1, I get the Output video. When I change the return feed back to NONE, I still get the return feed. Looks like a bug to me.
Using a Samsung Galaxy 6 as the caller through vmixcall.com
- Tom
grantcoll
#3 Posted : Sunday, March 22, 2020 6:19:19 AM(UTC)
grantcoll
I have this problem as well. Only Output 3 turns off return video. All others, including None still send the video. Only interim option is to lower the return video to the minimum saves on bandwidth. Eg 300Kbps.
Will log a support case
grantcoll
#4 Posted : Sunday, March 22, 2020 12:52:11 PM(UTC)
grantcoll
Got a reply from Martin on this issue. If you select None when you create the Call Input, then it does not return video. It is a limitation of WebRTC, but this workaround works perfectly.
