Change IP adress of Webcontroller
Joined: 2/18/2019(UTC) Posts: 59  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hi!
My PC has two network adapter, one for my local network (other PC, Router, ATEM Controller...) and the other for connection to the timekeeper network what could be different from my local. And these IP adress could change from event to event.
Unfortunately, the web controller was configured with the IP of the network card for timekeepers network. And now I want to change that and enter the other IP, but that does not work in the settings. Where do you do that?
Thx burie
Just use the IP of the vmix machine of the network you like and append the port example: NIC 1: 192.168.0.2/24 NIC 2: 192.168.1.2/24
The webcontroller is opening by default on NIC 1 (192.168.0.2:8088). All you need to do is inside the 192.168.1.0/24 network to open the 192.168.1.2:8088 and you will get the webcontroller. So to say it works on all IPs. just append the port. Hope that helps.
 1 user thanked mavik for this useful post.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
Thank you for the explanation. I had asked a similar question to this one previously, but this finally helped make sense of it.
