cruiseweekTV
#1 Posted : Tuesday, September 17, 2019 12:00:31 AM(UTC)
cruiseweekTV
Was thanked: 3 time(s) in 1 post(s)
Can anyone help me with a script to change an input at 8 pm exactly, I dont want to use a countdown timer because that means each show I have to time it to the clock and set the exact amount of time till 8 pm and start it at the right moment, I am hoping there is a simple 2 line script that can do this.
stevespaw
#2 Posted : Tuesday, September 17, 2019 12:08:18 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
cruiseweekTV
#3 Posted : Tuesday, September 17, 2019 12:47:12 AM(UTC)
cruiseweekTV
Thanks, I loked at that and it MAY work however the transition I am going to is a video and the api for some reason dosnt start the video even if stat on transition in is checked.
stevespaw
#4 Posted : Tuesday, September 17, 2019 1:10:42 AM(UTC)
stevespaw
have it fire a script and do anything you want.
cruiseweekTV
#5 Posted : Tuesday, September 17, 2019 8:18:22 AM(UTC)
cruiseweekTV
if I could fire a script I could write the script directly into the scripting tab of vmix. surly this isnt that hard to do?
comporder1
#6 Posted : Tuesday, September 17, 2019 11:15:22 AM(UTC)
comporder1
You can do this with windows task scheduler and a VBScript to call any API function. Your script should look like this.....
FunctionsToRun.vbs
Code:
On Error Resume Next
Dim o
Set o = CreateObject("MSXML2.XMLHTTP")
o.open "GET", "http://127.0.0.1:8088/api/?Function=ActiveInput&Input=1", False
o.send
o.open "GET", "http://127.0.0.1:8088/api/?Function=StartStreaming", False
o.send
(line 7&8 are just there to show how to add additional API calls)
You can call any of the functions found here: https://www.vmix.com/hel...ex.htm?DeveloperAPI.html . And because the api is call via IP address, the script can run on any computer on the network.
When you create the task in Task Scheduler, add an action to call this Program/Script "%systemroot%\system32\cscript.exe" and then add the path to FunctionsToRun.vbs in Add Arguments like "C:\path to file\FunctionsToRun.vbs". Then in Triggers tab, make the schedule however you like.
Carey
thanks 1 user thanked comporder1 for this useful post.
mjgraves on 9/18/2019(UTC)
cruiseweekTV
#7 Posted : Tuesday, September 17, 2019 11:51:32 PM(UTC)
cruiseweekTV
sweet, thanks for that :)
comporder1
#8 Posted : Wednesday, September 18, 2019 12:07:03 AM(UTC)
comporder1
No problem.
I sometimes like to know that the script did fire. You can add this VBscipt to the Task....
sendemail.vbs
Code:
Set MyEmail=CreateObject("CDO.Message")
MyEmail.Subject="Videomixer PC Scipt Run"
MyEmail.From="myemail@address.com"
MyEmail.To="myemail@address.com"
MyEmail.TextBody="The videomixer PC has started a script."
MyEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendusing")=2
'SMTP Server
MyEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserver")="mylocalemail.server.com"
'SMTP Port
MyEmail.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserverport")=25
MyEmail.Configuration.Fields.Update
MyEmail.Send
set MyEmail=nothing
This script will not send to a password protected email server. I have a local email server that doesn't require authentication.
Carey
raugert
#9 Posted : Wednesday, September 18, 2019 8:10:04 AM(UTC)
raugert
Canada
You could do this with the vMix Panel Builder App if you like. Put the appropriate command into a button and set the timer field to 8:00:00 pm. You can add as many buttons as you wish if you want to send other timed commands.
https://forums.vmix.com/...Mac-Windows-Touchscreens
cheers,
Richard
