Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
Hi! Is it possible to add some trigger like "Overlay HIDE". Example - to use with Instant Replay. Description: When we use Replay with that trigger, it hide overlays like ScoreBug, comercial logo etc, and after finishing show it back. If no overlays, it hide show nothing. The great feature is to set Hide overlays in Instant Replay settings, whith check box wich overlay to hide (1, 2, 3 or 4)
Yes Yes, I know, I can add triggers overlay on/off.. But at half of the game or after the end, when I show all replays from quater/half, and overlays like scorebug OFF, I need to go setting uncheck triggers, than before start new quater/hal check it on. Oftern something happend and forgot to do that, You understand )
Joined: 10/10/2017(UTC) Posts: 5 Location: Sydney, AUS
It would be handy but as it currently stands, I set a trigger on the transition in and on the transition out to 'hide' the scorebug.
Look. After first half or period, We turn off scorebug and play all replays than after finishing we shows what happand on the bench or on the field. So we need to cheek out trigger "On transion out", because We dont need to show scorebug, after finishing all replays at the break, and after start next half/period we need to check in trigger "On tarnsion out". It's not comfortably, because you can forget to cheek out or in trigger... and so on
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
While there is some merit to this request i do not think : Quote: because you can forget is a valid argument. Part of a production is a well thought of plan including extra needs in case of like having an extra shortcut (not trigger) to OverlayinputAllOff in this case Other option is to rethink the trigger/shortcut process like in auto turn of , manually turn on for example I agree that checking triggers on/off is a bad idea
