Joined: 3/10/2017(UTC) Posts: 63 Location: Philadelphia
Thanks: 51 times Was thanked: 1 time(s) in 1 post(s)
It would be nice if Vmix could add a live polling option.
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
Wondering if you've taken a look at DirectPoll. It, using the browser input within vMix, will allow you to likely do what you want, to one degree or another depending on how creative you are. I've tested it and found it to be acceptable for some uses.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
hi Tuesday,
only thing I didn't like, it might've been the same polling one.. is that they have to live your little live world to take part so I felt it was engaging but not working towards the end goal as I'd like
Barney Box Lane wrote:only thing I didn't like, it might've been the same polling one.. is that they have to live your little live world to take part so I felt it was engaging but not working towards the end goal as I'd like I'm not exactly sure what you mean. However, if I'm reading correctly, viewers can answer the poll questions for up to 30 days, before they expire, or the author can close them at any time prior. One additional item. I'm not sure of how a poll would appear if one had multiple questions. I don't know if potential voters would see all the questions available, or just the one that the creator wanted them to see and participate in.
Joined: 10/10/2017(UTC) Posts: 5 Location: Sydney, AUS
+1 for FB Polling please.
Joined: 8/2/2013(UTC) Posts: 1,099   Location: Fairhope, Alabama USA Thanks: 590 times Was thanked: 202 time(s) in 168 post(s)
How do you see a Polling option working?
Would this be a WebRTC connection from a viewer? Would this be a website-based front end that downloaded date to vMix Data Sources?
Just curious.
- Tom
