calamityjane
#1 Posted : Wednesday, July 10, 2019 10:42:57 PM(UTC)
calamityjane
I have a GT Designer graphic Title with a couple of elements "hidden" to start out. At some point I want to unveil them. I am struggling trying to ascertain the correct syntax of the API script.
I am thinking it should be:
http://127.0.0.1:8088/API/?Function=SetImageVisible&Value=1ytvscorebug1.gtzip&Image=HomeP2.Source
where the scorebug is the GT graphic and HomeP2.Source is the element I wish to unveil
Currently vMix displays whichever element is first in the list of hidden elements in the Title.
Looking for the correct syntax of this shortcut
#2 Posted : Wednesday, July 10, 2019 11:01:03 PM(UTC)
where did you get the SetImageVisible from ?
Peter1000
#3 Posted : Thursday, July 11, 2019 3:31:29 AM(UTC)
Peter1000
Switzerland
Was thanked: 82 time(s) in 62 post(s)
I use a small, full transparent picture as source and load the „visible“ on demand.
#4 Posted : Thursday, July 11, 2019 5:56:11 AM(UTC)
i meant as API function
calamityjane
#5 Posted : Thursday, July 11, 2019 6:08:12 AM(UTC)
calamityjane
SetImageVisible is a function listed in the shortcuts for Titles. When designing the Title graphic I make this element "Show Visble Toggle" in the data tab. You can then use this shortcut to make it visible.
My issue I can't make it work ( I don't know the syntax) for the API script. It works in Web Controller but I cant find the right combination in the API script.
Whit
#6 Posted : Thursday, July 11, 2019 7:29:23 AM(UTC)
My apologies, i was still on .54 (not .60)
http://127.0.0.1:8088/API/?Function=SetImageVisible&Input=demo.gtzip&Image=Image1.Source , for the Image one can use also SelectedIndex=#
calamityjane on 7/11/2019(UTC)
calamityjane
#7 Posted : Thursday, July 11, 2019 8:31:12 AM(UTC)
calamityjane
Hi
Hurrah, your suggestion re SelectedIndex worked.
Thank thank you
Whit
#8 Posted : Thursday, July 11, 2019 3:45:32 PM(UTC)
To be honest it was all there not? :-)
be it Image or SelectedValue don't seem to be able to accept which when multiple images are in the title i case of an API request
Janne Adolfsson
#9 Posted : Wednesday, September 11, 2019 12:34:29 AM(UTC)
Janne Adolfsson
Am I just stupid?
I'm trying to use the function in a script like this
If Input.Find("ScoreBoardTop.gtxml").text("PeneltyH2.Text") = "" Then
API.Function("SetImageVisibleOff","ScoreBoardTop.gtxml","HP2.Source")
Else
API.Function("SetImageVisibleOn","ScoreBoardTop.gtxml","HP2.Source")
End If
I just want the image to be visible if there is a value in PeneltyH2.Text.
Whatever i do it just selects the first image i the title.
Any suggestions?
ryanlehms
#10 Posted : Friday, July 9, 2021 11:59:21 AM(UTC)
ryanlehms
For anybody else that stumbles across this thread as I did...
Here is a reliable way to toggle visibility on and off:
If (String.Equals(atBat, homeTeam)) Then
API.Function("SetImageVisibleOff",Input:="Scorebug",SelectedName:="Top-Inning.Source")
API.Function("SetImageVisibleOn",Input:="Scorebug",SelectedName:="Bottom-Inning.Source")
Console.WriteLine("Home Team at bat")
else
API.Function("SetImageVisibleOff",Input:="Scorebug",SelectedName:="Bottom-Inning.Source")
API.Function("SetImageVisibleOn",Input:="Scorebug",SelectedName:="Top-Inning.Source")
Console.WriteLine("Away Team at bat")
End If
And here is an incorrect way that intermittently works:
API.Function("SetImageVisibleOff","Scorebug","Top-Inning.Source")
API.Function("SetImageVisibleOn","Scorebug","Bottom-Inning.Source")
else
API.Function("SetImageVisibleOff","Scorebug","Bottom-Inning.Source")
API.Function("SetImageVisibleOn","Scorebug","Top-Inning.Source")
End If
dtraut
#11 Posted : Friday, October 22, 2021 3:55:08 AM(UTC)
dtraut
Question and was trying to do the same type of thing...
I have a text field with a number in it and depending on that number (1-8) I want 8 buttons to either be on/off using SetImageVisible.
I have this script but it doesn't seem to do anything and wondering if someone can help. Basically if it finds the text field with 6, then buttons 1-6 are on and 7-8 are off. Scorebug is the template. RedRocks.text is the text field with the number and button1.Source is the image. I would continue this for "1" through "8" with each having the End If. I only put the first 3 sections on here but you get the idea.
If Input.Find("scorebug.gtzip").Text("RedRocks.Text") = "8" Then
API.Function("SetImageVisibleOn", "scorebug.gtzip","button1.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button2.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button3.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button4.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button5.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button6.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button7.Source")
API.Function("SetImageVisibleOn", "scorebug.gtzip","button8.Source")
End If
If Input.Find("scorebug.gtzip").Text("RedRocks.Text") = "7" Then
API.Function("SetImageVisibleOff", "scorebug.gtzip","button8.Source")
End If
If Input.Find("scorebug.gtzip").Text("RedRocks.Text") = "6" Then
API.Function("SetImageVisibleOff", "scorebug.gtzip","button7.Source")
End If
#12 Posted : Friday, October 22, 2021 4:22:26 AM(UTC)
End If
Maybe have a browse through the "Scripting for dummies" post
It cant work if the functiosn are not correctly written
API.Function("SetImageVisibleOn",Input:="scorebug.gtzip",SelectedName:="button1.Source")
Also streamline your code with a smal for x to count found loops (less code)
dtraut
#13 Posted : Friday, October 22, 2021 11:20:22 PM(UTC)
dtraut
Duh, sorry copied wrong script. Yes, you're right with the Input and Selected name. Pretty new to the scripting and trying to make it all work.
Do I have the IF/Then line right? I want to pull a value from a text box and whatever that value is, then apply the correct amount of visible buttons. Actually, could I pull that value right from the API?
I've been through the scripting for dummies section and maybe I'm just missing it?
#14 Posted : Saturday, October 23, 2021 3:17:00 AM(UTC)
kiss
Code:
dim x as integer
dim count as string = Input.Find("scorebug.gtzip").Text("RedRocks.Text")
For x = 1 to Convert.toInt32(count)
  API.Function("SetImageVisibleOn",Input:="scorebug.gtzip",SelectedName:="button" & x &".Source")
next
dtraut
#15 Posted : Sunday, October 24, 2021 6:24:02 AM(UTC)
dtraut
Wow, I have a lot to learn. Thank you so much for your help. I was making that way more difficult.
Really appreciate the help with this.
Guest (11)
